Help Please
Jun 18, 2013
6
So I have a Samsung Admire 2.3 Gingerbread, rooted. I was playing around and I was using Go SMS Pro and figured why do I need the stock messaging app and I did back it up with ES File Explorer. I didn't realize it but I couldn't send or receive pictures, I found an option in the Go SMS app that lets me receive pictures but I still cannot send pictures. Now I tried installing the back up of the app I created but it keeps saying Install Failed. So now I'm stuck not being able to send pictures, can anyone help me with how to install the app again or install an alternative app that will give me access to send pictures.
Welcome to the forums!
I would suggest to flash a stock ROM to your device, and then re root. Sometimes stock apps are difficult to find, as Samsung doesn't release the .apk files.
Ok So I think this is one of the roms but I'm not sure if it's a stock rom, can you help and jsut tell me if it is a custom or stock?
Rom-CWM-2.3.4-Samsung-Admire-R720-MetroPCS-04-16-2012 - xda-developers
It looks like a custom. But, as long as you have Clockwork Mod, and yout model number matches, yoy shloukd be abke to flash it. Just make a backup of your current one. If you don't want to do that, try Samsung-updates . com. Look for your model number.
Sent from a M.O.A.R. Galaxy S3
Did you back it up using titanium backup or did you just copy/paste it to your sdcard. If you did the latter, just take a root explorer and drop it back into /system/app , then reboot to recovery and fix permissions.
Sprint GS3 Running TN's Msg and Chubbs
vdacau
