Help recommend a quality Nexus 5x rubber/silicone case?
  • Start date Start date
A
AC Question
Hey all,
I recently got my hands on a Nexus 5x and am looking for a decent rubber/silicone case.
Other than the Cimo Shockproof Case and SUPCASE, can anybody recommend any others?
(Tried posting links but the forums didn't allow.)
Thanks
Re: Help recommend a quality Nexus 5x rubber/silicone case
Are you looking a case to protect your phone or just to house it in a case to add some grip?
Huge fan of the Cruzerlite TPU cases. I like that they don't put buttons on the buttons but leave cutouts for the buttons on the phone.
Nexus 5X Case, Spigen [Thin Fit] Exact-Fit [Black] Premium Matte Finish Hard Case for Nexus 5X (2015) - Black (SGP11756) by SPIGEN http://www.amazon.co.uk/dp/B0147JXU...ag=hawk-future-21&ascsubtag=UUacUvbUpU4963267
I bought this Spigen case on Amazon great fit adds grip and helps find the Nexus imprint sensor even more and it adds zero bulk to the phone, protection wise if you drop your phone it would only slightly help it.
This is what I have recently ordered. It's just a simple rubber frame bumper for the Nexus 5X but I think I will be pleased with it. It's made by Evolutive Labs
This is a super late response but as the OP of this question, I thought I better reply.
Firstly, thanks for all the suggestions. I eventually got this iGadgitz
Rubber Silicone case
and couldn’t be happier.
It’s so great finding a soft, silicone case in a market dominated by TPU cases which don't really absorb shock.
Marabishi
