HELP: Stuck in Android system recovery (3e)
blada4life
17
some facts:
I am rooted and run the Ace 2.0 rom EC05. i was trying to flash a dialer using rom manager (never used before) and it told me it needs to reboot into recovery (i assumed it would be CWM). It rebooted into the android system recovery.
i can navigate using the vol buttons but i am unable to select anything. i cannot reboot or even wipe or anything, i am stuck on this screen.
why would this happen? how do i exit and reboot? someone help please.
Glad you got it. Second, using ROM manager will get you into trouble because currently there is only 1 custom kernel that supports ROM manager and that is the Clean Kernel and little or no ROM support on ROM Manager. Your better off at this point booting into CWM using Vol Down + Camera + Power buttons.
some facts:
How did you boot with the bottom touch butons?
the problem was that there was no way for me to select anything on the screen. when i hit the HOME button on the phone itself, it ended up selecting reboot.
strange that the volume rockers worked but the camera button wouldnt work to select anything on the screen itself, as in CWM
958ryan
