Help Stuck in Boatloader
ajglenn03
Went to update firmware. locked device through adb and fastboot. when i went to boatloader it could not find the new RUU that I put on the root of my sd card and renamed PH98IMG. Now I am stuck in the boatloader. what do I need to do to continue with updating the firmware?
I'm guessing the file is on the internal sd card, not the external, or it's named PH98IMG.zip.zip Do you have windows 7? If so, you just rename the file PH98IMG the .zip is already there, so if you manually put the .zip, you get a file named PH98IMG.zip.zip
Unfortunately, I'm smart enough to fix my own problems, but not confident enough to fix one over the internet.
XDA my friend, start reading. I know quite a few dudes renamed the file wrong, and I'm sure there is a fix over there for it.
I renamed it the right name, but still not picking up in bootloader. Posted on XDA but no replies yet. Just dont want my phone bricked.
As mentioned above, did you store the file on /sdcard or /sdcard2? /sdcard2 would be the proper place. Since your phone didn't actually update you could just reboot it for normal operations...
RichardDixon
