Help! Stuck in bootloop
kixazz2529
15
I rooted my phone using PwnMyMoto and over the weekend was prompted to do a system update. I attempted to snooze the alert and unfortunately accepted the update and since my phone has been stuck in a bootloop loading and staying on for ~45 seconds then rebooting.
I've downloaded HouseOfMoto and have everything setup although when I run it it stays on waiting for device.
Two things I've noticed:
- For the 30-45 seconds the phone is on it is not recognizing that it is plugged into my computer.
- When the phone is on the battery shows at 44% charged but in fastboot it shows as low battery, and from time to time when rebooting it shows as 0% then reboots.
Anyone have a similar issue that could point me in the right direction please! Thanks!
Got it....needed the original usb cable. Will leave this up in case this helps anyone, but the usb cable is critical.
khatunkhatunc
