(Help!) Stuck in clockwork mod recovery...
mjpaxson121
3
Ok, so when my Nexus S reboots it goes straight to the boot loader without holding power and the up button. I accidentally deleted the cm9 by formatting the sd card. So I have no files on my device. What can I do? I have tried to mount the sd card but to no avail. Any help is greatly appreciated. I have no other phone to use. Thanks all
Not sure if you've fixed this, but best bet is to download CM9 on your computer, pop your SD card in and move the zip over. Sounds like you also have to flash CWM or twrp via fastboot. Hope this helps.
Sent from my Unicornified, LK'ed-out, 4.0.4-driven LTE GNex
Also in some cases even after flashing cm9 or any rom really you may get a recovery boot loop in CWM based recoveries try using the Canibal Open Touch recovery its the best. you have to go to advanced options then quick fixes. Get the v2
Wipe the dalvic and go for a clean install and factory restore I hope you got an SD reader do like demonzell said go for the clean install
Kinita
