[HELP] Stuck on modem.bin ! Please help !
ILham Zulkarnain
Hello ,
first im so sorry for my bad english language, i hope you are understand ,
and..
i have problem installing my epich touch 4G
i dont know why i keep getting stuck on modem.bin on odin PC
i try many firmware, and stock firmware to, and keep give me stuck on modem.bin
i try download on xdawiki, on sammobile latest firmware, stock firmware and give me stuck again on modem.bin
you will see stop icon left behind the battery indicator
any advice?
thank you very much..
im on the same boat only it displays firmware upgrade encountered an issue please select recovery mode in kies & try again but wean connected to kies it only shows A spinning ring and never loads wean i try to flash anything it always get stuck on modem.bin
I would say there is a problem in the line of code for the kernel. First question: Did you guys download a kernel for the Epic 4G Touch (E4GT)? If you didn't or are unsure, find one that is or go back to a base build that works. Just because it is a kernel for the S2, doesn't mean it is for the E4GT. Second, what version of ODIN are you using? I think the best version right now is 3.04, and some builds prefer one version to another.
If you are absolutely sure you downloaded the right files, install an earlier build on ODIN, delete and redownload the file and try again.
