*HELP with MicroSD/usb syncing with laptop- casio commando *HARD*
J0LL3Y
So, I have the casio commando phone. I haven't rooted it, or anything else crazy like that, yet. But i will eventually. I Have a windows 7 laptop and when i use my usb cable to try to sync stuff (not just transferring music, or else i would select that), nothings comes up. My phone has 3 different options. 1. Charge 2. Music transfer 3. Mass storage. I already found another post with the driver files, so i already downloaded that, and nothing. I found a way to play emulators on the phone, and i need to transfer files to the sd card so i can play those games. Also, I cant just plug my sd card into the adapter and plug it into the computer, because apparently only newer laptops can read sd cards over 2gb. Good lord. i just want to play pokemon so i can pass some time. So can somebody please help me?
Re: *HELP with MicroSD/usb syncing with laptop- casio commando *H
1) Did you install the drivers under "Charge Only?" (wierd, I know)
2) Do you have adb installed? (there's a way to manually push files, but we'll save that for last)
3) When you goto device manager, when your commando is plugged in, what does it say your commando is?
4) You use mass storage mode, right?
MizzBizzzzz
