Help with poor battery
androidsrkewl
I have a Moto z force and I'm hoping for some help identifying its battery problem.
Using GSAM I see that the kernel keep awake time perfectly matches the amount of time the battery spends awake instead of in deep sleep. Any ideas for how to figure out what's causing it or how to fix it?
Wakelock Detector and BetterBatteryStats aren't identifying any major wakelock culprits.
Any help is greatly appreciated. Thanks!
Welcome to Android Central! It'd help to see those stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/ge...ide-how-post-screenshots-android-central.html
Beboomo
