Help with rooting and choosing a stable Froyo ROM for Sprint Hero
brooklyn
11
I've finally had it with Sprint's/HTC's so-called fixes and the phone lag and plethora of other issues and I want to root my device. I've been on the fence for quite some time but I got the final push last night when a Sprint Tech Support Rep told me he's never had any issues with his hero but then pointed stated: "I don't run Sprint's version of the software on it, either." He told me I can root and if I ever need to send it in for a replacement I can just reflash the 2.1 update that's on Sprint's website.
So my questions are: What is the best way to root the device? AC's/XDA's command line option? One click root?
What is the best and most stable ROM with Froyo that will add to the features my handset currently has? I don't want to trade in one issue for another. And by issue I mean no preview for the camera, GPS errors, not being able to update PRL, etc. I understand no software or OS is completely flawless.
I don't care much for themes and such, I use Launcher Pro with my own icons and widget setup which is what I believe I'll stick with for the near future.
Basically, I want Froyo, as stable as possible and I want it to be a one shot deal. I don't plan on swapping ROMs every other day. I want something that's going to work, and good!
Thanks to all in advance for all help, guidance, tips, suggestions, corrections, and everything else you guys can throw my way. You're the experts and I'm the noob, help a brother out! lol
Thanks for the recommendation. I've been looking at CM6 for a couple of days. It was actually what the Sprint Rep recommended.
I've been scouring the forums, xda included, but with most threads reaching 100+ pages it's becoming almost impossible to read them all. And a lot of the devs and posters automatically assume that everyone reading knows what they're doing, to a noob they might as well be speaking Hindi.
I wish everyone's tutorials and explanations were as simple yet insightful as gbhil's tutorial on rooting. I mean, once rooted HOW do I install a custom ROM?
Once rooted, download Rom Manager from the Market. Then, just download the CM6 rom and place it on your SD card. Launch Rom Manager and follow instructions. Install Clockwork. Click to back up current rom. Then, click 'Flash Rom from SD' and select the CM6 rom you put on your card. Sit back and let it do all the work.
It's really that easy. Make sure you don't get any pop-ups when launching Rom Manager. You must set debug mode on. If things aren't set up properly, pop-ups will let you know.
Reactions: brooklyn
So I tried to root using gbhil's method but I got a message saying:
[1] killed /data/local/asroot2 /system/bin/sh
Does anyone know what went wrong? I downgraded to .5, not .6 and followed the instructions line by line.
Ok, so I'm really late in my reply but I wanted to thank you all for the help and advice. I was finally able to root and rom my phone with the universalandroot and rom manager. What a cinch!
I can say that I'm getting the itch to try out more roms and see if anyone fits better than CM6, which I'm really happy with, but curiosity is getting the best of me. Anyone else have any recommendations?
Ah, you feel the pull of change! Lol, flashing roms can get addictive. I don't flash new roms very often, setting my screens back up is a pita, usually, it's themes. Check out xda hero boards for a great selection of roms and themes.
Sent from my CDMA Hero. I got some hot Froyo on Hero action here!
pamatika
