Help with rooting note 3
  • Thread starter Android Central Question
  • Start date
A
I swapped a phone with my friend and he told me mine is rooted.
I have text on my pulldown menu which is as follows:
Device model : sm a710f (this is j3 model i think , but mine is definitely a note 3)
Android 6.01
Aspire team c9 v5
Wifi n signal blah blah blah.
Aspire is the rom installed according to google.
But when i try to download superuser as , it doesnt work. I used a root test app but it says error. I googled the error and a chap says rooting has failed or malfuctioned and needs rerooting ?
Can someone please jus tell me what on earth im doing ?! Haha im completely clueless need a step by step
mustang7757
Super Moderator
Moderator
Feb 6, 2017
94,682
9,787
113
XDA Forums probably be best bet to root and custom Rom...but make sure you know how to go back to stock firmware in case anything don't work right.
Rukbat
Retired Moderator
Feb 12, 2012
44,528
28
1. Does it take a microSIM (Note 3) or a nanoSIM (A7)?
2. The Note 3 Aspire ROM works on only the following models of the Note 3 - N900D, N9002, N9005, N900W8, N900A, N900T, N900V, N900P, N900K, N900S, N900L, SC-02F, N9007, N900R4, N900J. There's no "F" model of the Note 3. (If you're reading that from the ROM, that may be where it came from.) The Exynos models aren't supported.
3. Does the back cover come off, allowing you to change the battery? (If not, it's an A7.)
If it's one of the Note 3s, get the ROM from https://forum.xda-developers.com/galaxy-note-3/development/rom-aspireteam-c9-pro-v2-0-t3610152 (post 2) and read the bottom of post 2. (And install Magisk, not SuperSU. Use the current Magisk zip - his link to 14.2 is long dead. If you need the safetynet zip [dee if Magisk passes first], the link in his post works.)
Hibbertjayy
4
Its a note 3 device , but the model number says a710f . Im reading it from my pull down menu , ill try attach a screenshot.
The back comes off yeah , i know its a note 3.
This is where im stuck. Ill try your step by step but i can usually figure stuff out myself but ive spent days on google following all kinds of instructions. Ill reply soon with my progress
Hibbertjayy
4
Right , clicked the link on xda , its talkin about bootloaders and kernals and flashing.
Ive no idea what any of that is.
I need it explained like youd explain to your elderly relatives ! Haha
mustang7757
Super Moderator
Moderator
Feb 6, 2017
94,682
9,787
113
Since your not familiar, I try watching some YouTube videos to get familiar, as you can brick or ruin your phone not understanding .
Hibbertjayy
4
Ive tried for days , i dont understand 90% of it . Im usually good at figuring stuff out myself but this is screwin my head !
Do i need a pc for any of this ? Coz a lot of what i read mentions usb
Hibbertjayy
4
Right , ill try explain more .
I want to use finance apps like halifax bank , but phone is rooted. Figured i try take advantage of rooted phone and mess with some apps like wifi 'testers' . Im not doin anythin seedy just curious .
Basically the advantages of root arent working , but everythin else thinks its rooted.
Aayumann Gamerz
