Help with rooting.
Monkz8897
Active member
Oct 25, 2011
25
Ok im not a noob at this s***t just need some more help i recently had to go back to stock so i tried the ViperRUU.exe followed intstructions now i do want to try the stock w/goodies rom but for some damn reason i cant get root access it says i have root access and i even downloaded the root checker so what am i doing wrong here?? i'm runing a stock rom that is on 3.16 hboot 2.09? Help plz.
yeah which is really weird i booted in to recovery the day before and it didnt have one and then i booted into it yesterday and it says i have twrp 2.4.4.0 so idk how that could have happened i'm thinking its tweeking it self
If your on a stock rom you wont have root access unless its a stock rooted rom. A lot of people new to rooting make the mistake thinking that a unlocked bootloader means root. Its not. Its the rom itself that is rooted which gives you full access to the system files. A unlocked bootloader only means that you are able to flash a custom recovery so you can flash a rooted rom or superuser.zip.
So then I can just flash a Rom with root capabilities with out bricking? Or anything like that.
Sent from my EVO using Android Central Forums
Normally I do this stuff when I'm drunk cause I get a better idea of it but sober nope not this dumby lol
Most if not all custom roms will be rooted
OK, so what you are saying is that with an unlocked bootloader, I can go ahead and flash a rooted ROM onto an unrooted phone? Yesterday, I got my bootloader unlocked w/ no problem. However, every root tool I could find was unsuccessful in rooting my phone.
Sprint HTC Evo 4g LTE
Jewel PVT SHIP S-ON RL
HBOOT 2.09.000
Software Version 3.16.651.3 iord
HBOOT 2.09.000
Yes, a unlocked bootloader allows you to flash a custom recovery so you can flash roms, So install a custom recovery which i recommend TWRP ,
SpinjamShopeepinjam
