Help with transferring!
dhenzellao
Hi guys! I got my new Samsung S5 and I backed up all of my Samsung S4 files in Samsung Kies. How do I transfer all my old files from Kies to my S5? The Samsung S5 only works with Kies 3 but the file isnt there it's in the older Kies. Help please!
Have you tried smart switch mobile? I was able to get my stuff from my 5s to my s5 with that app.
Sent from my SM-G900T using AC Forums mobile app
Why don't you just copy all your files opver to Google Drive and then import them into your S5 from there?
used a combination of SD card, google account, and Samsung Switch...amazed at how thorough it is! All my settings, preferences, and apps were placed on my S5 just as they were on my S4! Just some minor tweaking and it was ready to go!
Cheers
After backing up your S4 you simply restore this file to your S5 the files should be in the default folder Kies3
Some account settings will not be transfered
Screwgoogle
