- Jul 2, 2010
- 16
- 0
- 0
I have two Nexus 5x's, one for me and one for my wife, both on Google Fi. Both are having problems with wifi at home. My router is a TP Link Archer C5 and no other devices seem to have issues with it. I run both a 5ghz and a 2.4 ghz networks and the phones are configured to connect to either.
Here's what happens - wifi connection will be fine and then, randomly, will stop working. No network access. If I turn off wifi or switch to the other network (5 or 2.4 depending on what I was on when it happens) it works fine. It just seems to get stuck. Similar issues have been reported for a long time and I was hoping the latest update would fix.
Here's what I've tried (I'm fairly tech savvy):
1. enable 5ghz or 2.4 ghz connections only on phone
2. increasing DHCP lease time on router
3. updating router firmware (it was already at latest)
4. forgetting the networks and re-authenticating
5. making sure Keep wifi on during sleep is set to always
It doesn't seem to happen outside of my home network, though I'm not connected to other networks for very long very often. I'd say it happens 2-3 times per day. Anyone else experienced this? Any suggestions for things I can try on my phone or router?
Thanks!
Thanks!
