help !!
sleepyrey
67
For some reason when i downloaded titanium backup it tells me *sorry, i could not acquire root priveleges. this application will not work" why is that when i just got this new BAMF Forever 1.0.6 please help
Are you sure you have root privileges??? Check by going to the hBoot screen - Power off, Press and hold the Volume Down, while holding this down press and hold the Power button, keep holding both for at least 10-15 seconds, then let go of the Power button, then the Volume Down button... the white screen is the hBoot... does it say S-Off or S-On???
when titanium gives you this problem instead of a reboot go to the market and download busybox. clear data on titanium and that should do it
valentinhinojosa
