Help!!!
May 16, 2010
9
when i hold down the power button and home button to get into that menu i get a black screen with a red arrow or something like everytime. is there a way to fix that or could somebody tell me wat it is..... thanks
It's the factory recovery. The RA recovery didn't flash. Check the filename of the recovery and flash again using whatever its called
i just flashed my phone to the real android 2.1 from sprint but i was was doin that when i used that leaked test version so is there any way to fix that
You flashed the latest leak using the RUU recently posted? Why did you do that? Didn't you see FOR THE DEVs?
You're out of luck, sorry. For the devs= for the developers to hack up and make a ROM. This version isn't rooted and also comes with radios. Running this unroots your phone, and puts on a ROM that isn't currently rooted. You're going to have to sit tight from now on and MAYBE, someone finds an exploit, but don't count on it. You no longer have the RA recovery on there because it was overwritten.
dear god do people flash blindly over here too?
you have two options as of now
1) wait for the devs to find a new root exploit
2) throw your phone off the roof and claim your warranty before 2.1 becomes standard
thanks for explaining this to me. and one more thing is there a way i can get live wallpaper or do i need the ra recovery for that
Yashnareddy
