HELP!!
whodatkiid
21
Just got the OTA update push to my tbolt. I am rooted through revolutionary running 2.11.605.3 leak'd, what will happen if i go through with the update? Total newbie here, rooted just for free hotspot. Any input would help!! I had to defer the update or else it wouldve done it on its own. Thanks.
Yeah, don't download the update. Revolution is tons better than stock, anyway...
Sent from my ADR6400L using Tapatalk
To answer the question, best case you loose root and all your data, most likely you will end up in a boot loop, worst case you end up with a $600 paperweight.
Yea can't have that happen. So how do I stop it from automatically updating itself, when it reaches the defer date I sent it on?
Look for the rooted stock rom, download it and install it. You will not be prompted since you will have the latest version. Do it before VZW updates your phone for you.
What he said, or choose a custom ROM...
RichardDixon
