Help
The phone can tell if guys use it to take pictures of themselves half naked in the bathroom, and if they do, it takes away features that are normally available. So knowing that, I would never, ever do that again and you should be fine.
That pic was with gb... At least it was the top half! Haha...
Droid razor maxx
Very true. Bottom half would be disconcerting. I think the only way to disable or enable data is with the toggle at the top of the "Data Usage" screen in the settings. I looked all over and can't find anywhere that just says "Data Saver". Seems like if there was that option, it ought to be in the "Data Usage" section...
Reactions: d.meyer
holy shiz! 1368 things waiting on it. That's odd. I have gone through everywhere I can think in my menu's and i'm just not seeing a data saver option. I thought I saw one like a week ago, but I can't find it now. Maybe it's one of those weird locations they chose to put it.
I know i'm dying to figure this out! At least the screen shot works!
Droid razor maxx
Just a shot in the dark..but
Settings
Under "Wireless & Networks" tap "More..."
Tap Mobile Networks
Is the "Data Enabled" option Checked?
That's a good point. But on his screenshot, it's showing 4G is enabled.
You know how in the Data options you can set the cap, and set warnings and how each app uses data is all broken down? Maybe that's the new, more involved "Data Saver"? I don't know......but maybe they chose to make it more involved than just checking a box. That's the only thing I can think of.
Tried both still nothing... All these genusis can't get it figured out Wtf
Droid razor maxx
If you go into settings, Data Usage, is there a check next to the Set Mobile Data Limit option?
Well, I can't find anything on how to turn off Data Saver on ICS. The only option I see is in Play Store > Settings > Uncheck "Update over Wi-Fi only" , but I seriously doubt that is the solution to your problem.
Your best bet would be to just connect to Wi-Fi to upload for now until more documentation on the matter surfaces.
That didn't work either... I wonder what these 1,300plus updates are?
Droid razor maxx
As for the original problem, I've noticed two things that try to Auto upload and has settings to disable auto uploads if that's what you prefer. MotoCast Settings in the My Gallery or Google+.
KidColoringPage
