help
Jamie Moseley
I plugged my phone in last night when I went to bed and now it wont turn on I have tried taking the battery out, tried plugging it in with a different charger I have tried the reset and nothing happens please help. :'(
Welcome to the forums!
Can you try a different battery?
If the phone is completely off and you connect a charger, you should see a battery graphic on the screen (and perhaps a red LED). Do you get that?
If not, leave the battery out for 5 minutes, put it back in and (without trying to turn it on) connect a charger. Do you get the battery graphic?
If all else fails, take the battery out, connect the charger and try turning it on.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
KidColoringPage
