help !
wellyjamal
Hello all.
2 days ago I've updated my galaxy grand-duos android from 4.1.2 to 4.2.2 .
I have had some problems at first..including apps problems.
every application started crashing..so uninstalled and reinstalled them again & they worked just fine .
I still have a problem with one app, which is instagram.
Since I updated my android , I cant upload pictures on instagram anymore except for the pictures that were on the phone before the update.
I tried uninstalling & reinstalling instagram many time & nothing happened.
I really need help on thia issue.
thanks.
Hello all.
thanks.
Welcome to the forums.
The problem seems to be the app, not the phone at least. Have you contacted the developer about it?
Thank you for welcoming me and replying.
I was worried if it was the device and I was about to reset to factory data
Because I searched the problem online and havent found any solutions.
No, I really dont know how to reach them :/ .
Easiest way is open Play, go to the app, and scroll down. Contact developer should be there. Click on it and your Gmail/email app should open with the Dev in the sending to slot.
From a Sprint Moto X using AC forums app
clhjr
