Help !!
Apr 10, 2014
5
So I shattered my note 10.1 screen and as I was replacing it, the sd card holder snapped off a small circular thing (don't know how to describe it). Now I am scared if I turn it on.
Thanks for any advice
Welcome to Android Central :)
It should still boot fine. If anything you won't be able to use the SD card slot anymore. Did you finish replacing the display?
Sent from my Galaxy S4 running SlimKat 4.4.2
Tdoperfdu
