HELP!!
  • Start date Start date
A
AC Question
my gs3 4.3 mobile data always turning off , and when i want to use a app on my phone i have to go bak to my settings and turn it back on but then it keeps turning off again, why? help . how do i make it stay forever?
Are you using any apps, such as battery savers or Smart WiFi managers, which have the ability to turn off your mobile data? Or does it happen whether or not you are not connected to a WiFi network?
Do you have any limits set in your mobile data settings? Is your battery low?
collingsmwale8
