help
swagdb
So i am rooted and was running the voodoo lag fix. i went thru the process and removed voodoo completely (pain in the butt). After trying to run a custom rom i found my phone has 0.00mb internal. WTF! i thought removing voodoo would fix this. not only that, my SD card is blank. i tried running odin and pushing the stock kernal and recovery but the phone says it cant find the update.zip file. can anyone help me or do i just have a new paper weight
you didn't follow the steps correctly then.
look for the how to completely remove voodoo thread on xda. follow that exactly, then come here and follow the FC hell thread
after that you should have a working phone
I just used the uninstaller.zip that he provided at the bottom of his first post in the thread on XDA. Worked fine for me, after it was done uninstalling i just flashed back to my "stock" nandroid and everything was fine.
hey thanks guy i finally had to reload voodo onto the card after dowlading the update.zip and cwm. just reload voodo, did the disable_lagfix, and deleted voodoo. worked like a charm
MorriTinni
