Help
Jennifer Metz
4
try to keep it short. I bought a phone.. Checked the imei that is clean. It's at&t then ordered my micro sims from straight talk. Then had my number switched to new sims. It works for 24 hours then doesn't. It says system is blocked. Straight talk says there is a block from at&t. Can the phone have a clean imei and still be blocked from the carrier? I just want and need it to work. I have a son with autism and can not have a phone that doesn't work .
Where did you purchase your phone from and which phone model is it?
Loki Samhain
