PLEASE HELP. Can't fix a strange error on android?
That code Error 1 (-2147483648)
Usually a generic Media player code.
The media framework failed, but Android doesn’t know (or won’t say) why.
I did see it that post. I thought I included this upcoming as part of my other post, but I didn't:
For the error: Did you copy the entire error code? If they truly said a -1 code means <whatever they replied>, by all technicalities a error code -2147483648 is different.
Yes, that was the entire error code. I simply copied and pasted it. I changed nothing. The entire error code from start to finish was "mediaplayer error 1 (-2147483648)". I should inform you that I got another email from the app developer, and they said it makes no sense why restarting the phone didn't fix the problem. That should have worked. They also said they haven't received any other reports about this error, so it's probably only effecting me. If the problem is caused by the android's operating system media player, then EVERYONE who uses the same android operating system as me should have the same problem (I have the latest android OS). So it might just be the audio files are corrupted. However, it's strange for thousands and thousands of audio files to all become corrupted at the exact same time. That's what I don't understand. Why all at once? And why so many of them all at once?
Sometimes copying , transferring them can get corrupted especially in large amounts
Reactions: Laura Knotek
I'll continue to experiment and try different things and different apps. I'm still exchanging emails back and forth with the app developer too, and we exchanging different ideas on things to try. If I ever find a solution, I'll immediately let you know and post it on here to help others. Thank you so very much for all your help so far. You've been fantastic and a great help and I appreciate it.
Thank you!
Yeah definitely if you find a fix let us know
lencaiboncai178
