help
raidil
Active member
Feb 23, 2011
43
Is any ones screen going half black whining u bring up the setting in the bottom right
yes, mine goes part black on the right side.. I believe its normal.
Are you talking about the right hand side having a fade to black affect? If so, I think it is supposed to do that.
When you touch in the notifications area of fades put that side of the screen touch elsewhere it will go away. Built in feature talked about in the honeycomb users manual
KidColoringPage
