Hi guys! I need little help about LAN connection issue on my new Android TV Box A95X R3?
  • Thread starter Android Central Question
  • Start date
A
WiFi connection work perfectly.
With LAN connection have some understanding issue for me.
1. I connect the box with Ethernet cable.
2. Box indicated connected?!
192.168.0.100
No proxy
DHCL
3. What works:
- kodi, albkanale, Gmail.
What not works:
- play store, chrome, YouTube, stremio, speed test. (No internet connection, check your ip adress or something like that!)
Thanks in advance for your help!
Ajet_Android_TV_Box
3
How long does it take for the Android TV Box A95X R3 4/64GB to finish the factory reset process?! Look, almost 16 hours writes only "android", no other information!
Thanks
Ajet_Android_TV_Box
3
I reset it to factory settings.
I waited 36 hours to restart and just install the program.
After that, the LAN connection is stable for the time being.
Android TV Box A95X R3 now works.
Only Bluetooth doesn't work for me, it doesn't recognize any device and I can't control the TV Box with an external application (RemoteIME).
Bye
xak47d
