Hi i am new to android and would like to have some solutions to this problems i face help ~~~
Alexandros1
19
So i wanted to ask how i can stop the vibration when i get notifications??
Also some apps keep working even when i stop them is there an app or something to stop them??
And what's the best app to play any video format??(if exists)
Thanks a lot~~~
For apps you never want to use, you can disable them. That should also prevent them from loading up.
This being said you should not worry much about apps in memory. This is not the old days. There are many articles online about this. RAM gets swapped out as needed. If you like, download Advanced Task Manager to kill apps every once in a while, but don't overdo it...
Regarding video, try VLC beta.
R
pramanj96
