Hjgh battery use, data, and storage use. Multiple cameras. Cam
  • Start date Start date
A
Android Central Question
When I look into permissions and app list I have the same or similar named apps one with a green android robot icon and some are blue??? One appears to be system and the other I can adjust or force stop anD the other has no option.
Welcome to Android Central! Which phone? This kind of thing is not unusual. There can be multiple system apps with the same name
If you're concerned about high battery use, then check your battery stats to see what's using it. Also, if you have poor cell signal, that can be a battery drain as well.
You can also look at the data usage menu in the system settings to get a better idea of what's using data.
Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/ask-question/409154-join-android-central-community.html
aimalee
