Hole Punch has notification led affect now
ZOMMBIE1
Trusted Member
May 24, 2015
786
For you Goodlock users update edge lighting+ and use the black hole affect
I'm having trouble finding this app "Goodlock". What exactly is the correct spelling of this to find it in the Google Play store? What does the icon look like? If someone can post a link to find this app in the Google Play store, that would be great! :-)
It's in the Galaxy Store app.
Thanks. Too bad it don't seem to work when screen is off. I can get it to work when screen is on tho.
And I found the reason why lol. I had to change settings in edge lighting from to show always to show while screen is off. I don't need the LED while I'm messing with phone since I get the popups lol.
does it stay on until you look at it like the led, or just light up for a few seconds and stop?
I downloaded Edge Lighting + by Samsung from Galaxy Store and I'm trying out the hole punch effect, but I don't get what this has to do with Good Lock. I don't even have that installed anymore.
Exactly, and can't set color per account, so not much use to me. Maybe features will be added over time.
Edit: looks like you can set different colors per app, but not necessarily per account.
It just stays on for a few seconds then stops
Hopefully so. I did go and turn on notification reminders so maybe that will help.
Update notification reminders don't make the LED to turn back on. How well. It's a nice start tho.
Edge lighting allows you to change the color for each specific app. At least with certain effects. I do wish the lighting would stay on until it's acknowledged.
Cause it's part of the Goodlock family of apps. Why on Earth would you not use Goodlock? Lol you might want to check it out, it is the best!
Back to led me know for me.
I like the notifications to continue until I dismiss them.
I had it, and found nothing in it that interested me. Also, I did not see anything about Edge Lighting + within Good Lock. I checked. It was simply an independent download in Galaxy Store.
I installed Good Lock several times to look through it and try out what it offered - but always wound up just getting rid of it.
Does the regular edge lighting still work with this option ?
Edit: nevermind . I see that only the hole lights up. I'll just keep my regular edge lighting, but I hope it's a good replacement for the people who miss the led light.
