Hole Punch has notification led affect now
try "aodnotify' in the play store. it ads hole punch notification rings that are more customisable, including the ability to have them stay on until aknoledged and it works along side edge lighting instead of either or
Will check it out. Thanks.
Edit:
Ok, checked it out. I'm having trouble getting it to stay on until acknowledged. Also, all these apps have one major problem for me. The real usefulness of the old LED is that I could set color per ACCOUNT - not per APP. For instance, my HUB email app let me set separate LED color for my work email as well as each of my several personal email accounts. So I could glance at my phone sitting on my coffee table and know instantly if I had a work related email waiting, or which of my personal accounts - so I knew if I needed to pick up my phone. These camera ring utilities, with color by APP, means all email accounts have the same color. Anyway, it's better than nothing and I wonder if you could help me in getting the notification to persist. Thanks.
To get the notification light to stay on until you dismiss or see it you'll have to purchase the Pro version. You can find "Pro" in the app. I think it's $2.99
Edit:
I have already purchase pro version - but I don't see how to keep it on. Only 1 minute duration.
Nevermind. I looked at the duration scale and the far right said 1 minute, but that shows the actual setting, not the upper duration limit which is 5h.
CliffHangerOld
