Holster for Surface case w/extended battery
byrds8
717
12
Title says it all. What holster will fit with the surface case for use with the extended 2100mah battery? or what combo works good with it other than the surface case.
Do you mean the Seidio surface case for the extended 2100mAh battery? The Seidio surface holster works with it.
Remember that the phone goes screen facing into the holster and the extended battery only affects the back of the device, so it doesn't affect the holster fitting.
