Holy battery drain, Batman!
redhdgirl417
89
I'm beating my head against the wall trying to do what I can for better battery life....I've shut off Google Now services per a thread on the forum, removed unnecessary apps from phone, have display set to auto brightness (which is too dark but trying everything I can), new OEM battery. I will say that I have terrible data coverage in my home but always on wi-fi and I've always understood that battery drain is better running off wi-fi than data anyways but pehaps phone is still reaching for that data signal? I unplugged from charger at 7:15, fully charged, and at 8:54 my battery is down to 76% (have only checked notifications, no surfing at all). All suggestions are MUCH appreciated. :)
How long was the screen on time? Possible the button was getting pressed in say a pocket or something?
Sent from my Sprint Galaxy Note II
the screen on time is always set to 2 minutes. The phone was sitting on my counter undisturbed.
Same problem here - phone came off charger at 7:00AM and by 10:30 was almost dead.
Hate to say it, but you likely need to do a factory reset. It is very possible that you have something in your temp files that is left over from ICS or GB that is taxing the processor.
I had a few issues, lag and freezing, and a factory reset solved them all.
Back up you data beforehand. Some stuff remained on the internal SD when I did the reset, but your mileage may very.
piikea
