Home button on my S5 and Google Now
1.Click on "google settings"
2.Click "search and now"
3.Click "voice"
4.Click "ok google detection"
5.Click" from google the google app"
6.Click the button from on to off.
Jacked from another thread. I did this & restarted and the problem is gone!
I FOUND A FIX! i called att and this of course is a known issue. -Go to settings -Application manager -Scroll to the left for "ALL" - scroll down and find "touchwiz home" -clear cache -clear defaults Hit home hit "always" to make touchwiz home defualt click ok. (I had 2 different TouchWiz apps I did this to)
I just went to app manager went to Google app cleared defaults found what it was trying to make me choose between in my case dragon mobile assistant and deleted it it's worked so far
This worked for me. I was able to turn Google search back on and everything seem to work correctly. Thank you for sharing.
After weeks of struggling with this and looking through this forum, I finally got my home button working properly. Its a simple fix.
Go to settings, then go to Accessibility, & then dexterity and interaction, then click the "Press and Hold Delay" Set it to 1.5 Seconds. Google now will not appear unless you really hold in the button now.
Sorry...this doesn't make any difference with this problem. Give it a day...it'll come back. I'm pressing my home button at lightning speed and its still coming up. I hate this phone more and more every day.
Hey everybody, this is my first post on the forum.
On my galaxy S5 recently, over half of the time that I want to go home, and i hit the button, it just takes my to google now instead. Is there a way to change this setting?
Thanks
I was having this same problem! So annoying! I finally figured out you can go to your apps and uninstall the Google app. I didn't mind doing it since I never used it anyways. Hope this helps!
Ok I found this and so far it has worker perfectly and my Home button is so fast again, just flies back to the home page:
You have the wipe the cache of your phone, not the apps.
"As first thing, turn off your Samsung Galaxy S5/S5 Active by long pressing on the Power On / Off button. After the phone is complete off,you need the following key combination to boot the smartphone:
Press and hold:
• Power On / Off
• Volume up
• Home-Button
If the Samsung Galaxy S5 vibrates once, release the Power On/ Off button but keep the other two keys from the key combination pressed until a boot menu appears on the display.
Now mark the entry "Wipe Cache partition" with the volume quieter button. With the Power On / Off button confirm that procedure. This function takes only a few seconds. Then the previously displayed menu reappears. Now select the first entry with "reboot system now" and run the command again with a press of the Power button. Your Samsung Galaxy S5 will now reboot and start your Android OS.
Done!" Enjoy!
I uninstalled Google for about a week and reinstalled it and that seemed to make the problem go away. I don't see it happening after my upgrade to Lollipop either.
This worked the best! Although something made me reset my home screen and apps. O well, it's better than the silly google hangup!!
for those of us lurking and waiting for a fix, AT&T announced releasing lollipop for the S5's on wednesday.
search android central for samsung-galaxy-s5-att-now-getting-taste-lollipop (can't post links because this is my first post... that's stupid!)
I am sooooooo tired of updates that ruin phones. The thing is, these phones are not cheap. So we spend all of this money because we want a phone that works good. We want these special features and better processing. But then once they're home a few months, they update them and all these problems start. I seriously think it would be a valid lawsuit that an upgrade MUST actually make the phone BETTER, not more annoying like this update. I don't want to go to Google Now. I also don't like that it is recording my conversations and giving me "suggested" ads based on things I've discussed. They said it's all computer done and doesn't save anything, but I hate it. Specifically what I was discussing had NOTHING to do with my life and now I get ads about it (tires). It's very intrusive. And give us back our home button please!
This is how solved it in my s5:
search for "google settings" in google search bar of your s5.
goto search&now -> now cards.
enable "show cards" feature.
disable "show cards" feature. At this time it will ask a question about disabling "google now" and I said YES :)
I tried a lot of the suggestions on here and they were all temporary fixes. But 3 days ago I uninstalled the "Google Search bar" and reset the Home default to TouchWiz Home and without fail, it goes to my home page every time, it no longer goes to the Google Search Engine. I'm finally happy with my phone again after 2 months of this annoying problem.
Tiokujha
