Home screen doesn't rotate.
Set orientation in play much better and formats cleaner to.
Don't need to "root", hack it, install other launchers to do this simple thing. Unless you're just driven to hack the thing into submission. Just install the app "ultimate rotation" from the play store and you're good to go. Have also heard good things about Auto Rotate Widget.
Unless of course you're in to finding the most complex and risky solutions to simple issues, as so many on this forum are inclined to do.
So Nova pretty much does rotating for me on home .
Is there any way to rotate the lock screen without root?
The reason I changed the default launcher to Nova instead of just installing a rotation app is that Nova has some other customizations in addition to home screen rotation. For instance, I prefer having some transparency to the app drawer background, which is possible on Nova, but not on the stock launcher.
I also installed ultimate rotation control and it works smoothly without slowing anything down. So thanks who ever suggested it :cool:
