"Home" soft key mapping issues
JOrtenzi
610
102
Is anyone still having issues with the home key?
It does what is supposed to unless I am on any of my other "home screens" (I have 5 via Luancher Pro). When I press it, it doesn't take me back to my defualt home screen, but instead takes me to the multi-screen feature where all 5 of my homescreens are shown.
I thought the mapping was fixed? Am I the only one having this tpe of issue?
Thanks
Thanks
That is setup through your settings in LP. I am not sure which one, but I know you can change the home screen option to the home screen you want to use.
Reactions: JOrtenzi
Thats not the issue I am having... I have it set to take me to my 3rd screen, but instead of doing so, it gives me the multi-sceen (mini versions of all 5 of my screens are shown)
Ah.... ok, found that setting. I will "thank" you when I can get to a cpu.
Thanks!
Sent from my SCH-I500 using Tapatalk
Thanks!
You're welcome, anytime. I would have told you where to find it, but I stopped using LP and went back to GoLauncher, so I did not remember.
Seachild80
