Hotspot capability on Nexus 5
Ok, here we go. I used SQLite Database Browser (SQLite Database Browser | Free Development software downloads at SourceForge.net)
Pull the file from your phone and save it to your computer. It works best if you use a file explorer like ES File Explorer and save a copy to your SD card, and then transfer to your PC. Then, before you take any more steps, make a copy of it on your SD card named settings.db.bak in case something goes wrong and you need to undo what you did.
Then, open SQLite Database Browser from where you downloaded it.
Open settings.db:
Browse data:
Select global:
Click New Record:
Double click in the new fields of the new record and make them match below:
To do this, just type in the big text box and click Apply Changes. No extra spaces or carriage returns:
Save your changes:
Put the file back on your "SD card," go back into ES File Explorer, and push it back to /data/data/com.android.providers.settings/databases/ and reboot.
Also make sure that when you copy the file back it is owned by system and not by root, otherwise in my experience you will get stuck at the boot screen. Thanks afazel!
I can confirm that although hot spot starts, and devices get an IP from my Nexus, they cannot get to the internet. This is 32gb black on Sprint.
i use wifi router from the plastore on my sprint rooted n5 and it wirks great.
I don't have this folder com.android.providers.settings so I can't locate settings.db....help? :(
Never mind I'm an *****. Realized I need to find it using a root browser. I also had difficulty opening sqtlite browser on my desktop...I couldn't find the actual program itself just a bunch of files....I'm sure I was missing something. I remember reading I need qt something. Anyway I ended up just buying the sql app for 2.99 and did it through there and voila ..tethering re enabled. Thanks guys.
This might sound like a newbie reply, and if you're asking something more technical than this, sorry. Lol
I have T-Mobile's unlimited plan which includes 2.5 GB of 4G tethering, and it works without needing an additional app (for me, anyway... But again, maybe I don't fully understand the question).
To create a hotspot, I go to Settings-->More-->Tethering and portable hotspot.
I'm using a root explorer and I still can't find that folder nor settings.db. Any ideas?
Edit: Lost root when I sideloaded 4.4.1 and did the ota of 4.4.2. Changed all in SQlight, but when I rebooted, I'm stuck at the boot animation. Not sure what to do from here.
Reboot into recover. Hold power on + volume up. When recovery loads hold power then quickly press volume up then let go of volume up to get the recovery menu. Use volume buttons to factory reset and wipe cache. Reboot and see if that fixes the device.
If not, you'll need to restore a factory image.
Did have to do a wipe and reinstall to factory. Had to reroot and got done all my apps from installing. Apparently I forgot to change some permission on that file when I placed it back so that messed up a lot. Going to work on it at home when I focus all my attention to that. Thanks for the advice.
No problem. Glad to see you are back up and running.
I have T-Mobile also and even though they gave everybody free mobile hotspot but every other carrier makes people pay extra. Hell even we still gotta hack to use it past 2.5gb.
Sent from my T-Mobile LG Escape running 4.1.2 using Tapatalk 2 (Central n Ohio Austin IL)
How do you get past the 2.5gb?
WiFi tether for root users and this app on top
No it isnt as u can tell in my sig but I have good experience in nexus phones having used all but the 5. And u don't have to root to use the hotspot u just have to to use it unlimited.
Sent from my T-Mobile LG Escape running 4.1.2 using tapatalk 2 (Central n ohio Austin IL)
So just root without doing anything else, and run the app?
Uhm ok, I'll try it thought, if I have any problems I'll ask you for help if you don't mind ;)
No prob I'll give u screenshots of my settings and the app I showed in the screenshot is an app to hide your hotspot Usage to usual data in case your worried about the carrier.
emailists
