Hotspot problem
gt5059b
23
The hotspot should work even if I didn't pay for it till July correct?
When I turn it on, I'm getting a "Data Call Failure" message:
Error Code 67. Registration failure. Your PCS Vision username and/or password may be incorrect. Please Try again.
The hotspot works as devices can connect, but the data connection isn't working. I can't get any data from the broswer on the phone. When I turn the hotspot off then data works again.
Anyone know what the problem and how to fix?
Thanks!
I got the same error on both the wifi hotspot and the USB tether. I enabled 4G (I'm in a 4G area) and it works on both the wifi and USB tether now.
It looks like even the USB tether is restricted to 4G and will probably go away after the initial free period.
John
pakeezahere8
