How can I fix a call blocker problem?
  • Start date Start date
A
AC Question
I have a android 4.2
Whenever I download a call blocker on play google, my message notifications messes up. Any suggestions? I have to uninstall the call blockers.
Re: call blocker problem
Welcome to the forums. Is it the notifications that are getting messed up?
Yes. Also, I had another app battery full notification that also messed up the message notification.
Have you tried turning off notifications for the call block app?
No, but when I uninstall the 2 applications the notification popups worked. Now I I'm not sure what apps should I install. I don't trust that play google anymore :(
You had 2 installed at the same time? If so, that might have been part of the problem.
As for apps from Play, I would suggest getting your apps from them or Amazon. Anywhere else might just be asking for trouble.
This never happened like that before. I usually do download 2 apps or so same time. Don't know what to do :(
Sorry...to clarify, you had 2 call blockers? They might have been conflicting each other.
Ok, I install another applications. Its doing it again. Though. How do I fix this? :(
What device do you have? It might be an error in the OEM version of Android.
Its all call blocker doing it. I delete it call blocker and still doing it now. :(
makjojo
