A
AC Question
I have NFC enabled. I am using Trigger to program NFC tags. I have successfully created a tag that will open Waze when I'm in my car. I wanted to create another tag that I can attach to my laptop to open my mobile hot spot on the phone. I'm using the native hot spot app. The tag will turn off wifi, but it does not successfully turn on the hot spot. I don't know how to configure the Configure Actions box. There are 4 lines. First is Action, which I have set to Enable. Second is SSID. I keep putting in what the phone SSID is, but it keeps reverting back to AndroidAP. The third line is Auth type. I set that to WPA2 or Open and neither seems to matter. Auth Key is blank. Should I put in the password? Still doesn't seem to matter. Check box is for "use current configuration." Don't know if that should be checked or unchecked.
