How can I get my led indicator working?
Faisal Sadi
5
my led indicator wont working
Please help!! I had galaxy s4 gt-9500 v 4.4.2 the led indicator wont work i checked in the setting and i tried to install apps to help me but the led indicator wont working what i can do ??? ( some times the led light work but its to short time )
Re: my led indicator wont working
Welcome to Android Central! How new is the phone? That behavior sounds like a defective LED. Which apps did you install to try to control the LED? Light Flow? If none of them helped, then it's probably time to contact Samsung. If the phone is still under warranty, they should be able to fix it.
What can i do if nothing help how can i contact samsung ???
Where are you located?
In the US: Samsung
Otherwise, search Google for "Samsung warranty [your country]."
