How can I stop Verizon update
I was just coming here to ask the same thing! I'm rooted so I'll check to see if I can freeze the update app in Titanium Backup. What is the name of the Verizon Update app?
How did you root? In in the same predicament. Thanks
I think it's time for a class action lawsuit. To many users have the same problem. You can't deny an update but when you do it, it messes up the phone. Guess what, then you are forced to get a new one since you don't want to deal with the frustration anymore. First it was the "can't remove the battery" so the NSA can always listen and always know where you are even if your phone is off. Now you can't even enjoy your phone the way it is because they force an update. Even if it don't "F" up the phone or some apps, it still takes hours getting it back to where it was. Any law firms out there ready for a class action lawsuit. Take the case, I'm sure you will have thousands sign up.
Found a way to stop updates, Have less than 1.5 gig of space left. The update errors out and won't install. So go out and fill your phone with Netflix or Amazon movies and flip off Verizon.
pmm09
