How do I change the number of times my phone rings before going to Voicemail?
Re: Number of Rings before Voicemail
Yep, worked for me on my Moto X 2013 on Consumer Cellular.
The instructions were great and it worked for me after several attempts. I realized the code/number to enter was incorrect though. You had 2 stars before 61..... - it should only be 1 star. Once I figured it out, it worked. Thanks!
:D It works on my samsung galaxy S5 Android 6.0.1, with AT&T Wireless. Thanks (using 2 asterisks before the 61 in the reset call.)
On HTC Inspire, how do I change the number of rings or time before an incoming call goes to VM? The default settings seem low and most of my calls are going to VM before I can get the phone answered.
enGage
