How do I connect my Droid Turbo to my Plantronics bluetooth?
  • Start date Start date
A
AC Question
how do i connect my droid turbo to my plantronics bluetooth
WHen i search for the blue tooth from my phone it comers up empty
Re: how do i connect my droid turbo to my plantronics bluetooth
Welcome to Android Central! Which Plantronics device? Are you certain you've pressed whatever has to be pressed on the device to initiate the pairing procedure?
was the device you were searching for in discoverable mode? Which device are you searching for? May be you could try NFC pairing(if yuor other device supports it).
Did you read the instructions that came with the Bluetooth device . Usually works every time . And if you don't have them you can download them on the interwebs .
ShifaAttia
