How do I fix error code DF-DLA 15 when updating apps?
  • Start date Start date
A
AC Question
When I update any app this error code is showing and my update is not completed
I'm having the same exact problem on a brand new Samsung A800 I tried clearing the cache and removing / re adding my google account which was suggested for other errors, but it doesn't seem to help with this one. So frustrating, I wonder if it's not my phone though considering you just posted the same error and hour ago, and it is the only other reference I can find for this exact error.
What I did is back up everything that I have in it and do factory data reset and the issue was resolved.
The easiest way Start "Smart Switch" on your computer, plug in to the USB your Galaxy S6, it will tell you there is an OS update for your Phone, allow that, all your Apps will also be replaced, update them, worked perfectly for me.
Why copy a post that doesn't make sense? If you have any issues, the solution is in the thread. If you still have a problem, tell us what you have tried and what error message you get. Thank you.
Peeps for me, I re registered my google account but I think more importantly I changed my language settings to my correct location.
This is probs old but it hopefully helps someone.
B. Diddy, post 11. Thank you! I followed the instructions you provided and it worked! I'm not a technically inclined person so it took a few tries before I got it but, once I got to the right place in the applications manager setting, problem solved!
Thanks for fix. Tried everything several times & nothing worked ! I then removed my google account and added it back again and that worked a treat. Nice one......
gmcbride
