How do I fix my microphone on my Motorola Nexus 6?
  • Start date Start date
A
AC Question
How to fix microphone on Motorola Nexus 6?
My microphone stoped working. I can make calls and everything, but other side can't hear me. They hear only static noise. Has anyone had experience with this? I would appreciate any help.
Thaks
you might want to try to plug in a headset to see if people can hear you. If they can then try to unplug it and see if the regular mic works.
Re: How to fix microphone on Motorola Nexus 6?
Make sure that a case or misapplied screen protector are not blocking your mics.
any resolution yet?
mine went to Motorola ES 2 times, 1 motherboard replacement... doesn't...
went to expansys for 2 times now... 1 motherboard replacement... the same... micro doesn't work...
i'm going nuts with this...
Nehasingh12
