How do I fix my S5 with no sound during calls?
Sep 1, 2015
11
How to fix my S5 with no sound during calls?
Everything else works fine. I can use speaker phone and play loud music. I just can't hear anything when I make phone calls. I maxed out my call volume.
Re: How to fix my S5 with no sound during calls?
Try clearing the cache of the device and see if that helps. Let us know if it does or if you have further questions.
I tried to reset the phone to factory setting but still no sound during calls.
I thought it was the audio chip so i applied pressure to it from the back of the lcd part...it worked for awhile..then i put mire pressure...worked for awhile...then i repositioned my sims to the right more and its working again
..so..that may be the common issue is the sims moves ever so slightly and it doesnt connect...i have a micro sims and have to use a plastic tray with it...im gonna get ahold of my carrier and see if they have just a regular sims
mcheck
