How do I fix my screencapture system on my Note 4?
  • Start date Start date
A
AC Question
I am used to using the home+power buttons method to get a screencapture on the Samsung phones which I have owned. But recently after an application installation made the permissions a little messy, as well as the functioning of a few other applications.
I decided to totally uninstall all applications and reinstall them from Googleplay again. Now that it has been done, it seems like all is working but when I try to do a screencapture, I get the "Unfortunately, System UI has stopped" error. I've tried to change and use the screen swipe method but I still get the error.
Is something missing? Do I have to reinstall something from Samsung again? I didn't (and couldn't) uninstall system and pre-installed applications, so I don't think I removed any necessary items. What do I need to make sure is available and running for the screencapture system to work?
iheartpenguins
