how do i fix unfortunately measure has stopped in my phone
  • Start date Start date
A
AC Question
it keeps popping up and stops any activity going on in my phone.
If none of the suggested remedies described above works, I don't know that we have anything more to offer at the present time, alas. It may be worth contacting whoever has put those apps on your phone - manufacturer, retailer or carrier - and insisting that they fix the problem.
1) Try to figure out what app caused the malware to be introduced...
2) Find the best method to do a full factory reimage of your phone. A factory reset will not fix the problem as offending app puts some stuff in the system area, which will be immune to any factory reset. The steps to flash a factory image is highly dependant on the make and model of your phone.
I am having the problem of Unfortunetly the mobileOccr has been stopped any install any of the application when i start the net.so what i do tell me???
hello sir iam using huwaei y511u 30 my mobile not working properly some application auto restore such as egirl,hola lunch,andoied patch,when i saith on mobile unfortunently accebility serivece stop like that come i also hard rest but mobile not working plz give me soloution
I have Micromax A104 mobile with 4.4.2 KitKat os,from last 10 days there are many unnecessary apps like umstudio,mobileocr,engrils,time service,monkey test and many app there in my phone..when I checked app list running ,which causing my phone hang ,sometime I can't use my mobile because of these apps causing severe malfunction of my mobile.I applied all these above method such as soft factory test,hard factory test,force stop app,disable app..but can't fixed my problem
automatically in some time those apps came into again to my mobile..plz suggest me some permanent solution...I m waiting for reply
Welcome. :)
You may need to reflash the stock ROM.
websitedesig102
