How do I get the ability to print coupons using OS Chromebook?
A
AC Question
I have a cloud ready printer and want to print coupons from the internet from my Chromebook. Is there some type of app I need to download to make this possible?
LeoRex
Retired Moderator
Nov 21, 2012
6,223
Sites like Coupons.com do have mobile apps that will be able to print the coupons. If you look for the coupons.com app on the Play Store, there will most likely be other coupon apps listed under the 'Similar Apps' list.
dianehelen
998
A work around that's worked for me is talking a screen shot of the coupon, save the image, then just print it :)
Hope that helps
ackmondual
79
Hope that helps
For those too lazy to look it up, press Ctrl+{"the rectangle" button} to capture a screenshot
Press Ctrl + Alt + / to bring up the graphical shortcut reference for further details!
If the coupon's an image, you could also just save it as an image
MRG582
